Wires through firewall?
1.6K views 6 replies 6 participants last post by  baby GT-R
#1 ·
got a question here, how du you put wires through the fire wall? i have just hooked up a A/F gauge but i didn't put the wire that goes to the sensor through the firewall, i put it somewhere else, and was wondering how the hell u get wires through? do you need to cut a hole? if i find out how to do it i would like to redirect the wire through the firewall.
#2 ·
There's a gromet down by the clutch pedal, or where the clutch pedal would be if you have an automatic. I believe there's also one by the passenger side somewhere.
#3 ·
by the clutch eh, im gonna have to go run outside to my car and check, thanks, hopefully ill see it
#4 ·
i can confirm that there is a grommet on the passenger side... just peel back the carpeting in the foot well and you'll see it. (also easy to spot from inside the engine bay)
#5 ·
Use the passenger side grommet. MUCH easier. You cant miss it. Black grommet half way down the firewall with nothing going through it. You can sort of see it in this pic. Look just above the top right part of the intake manifold. The little hole with wires in it.
