Best fuel grade for QR25
6.2K views 26 replies 21 participants last post by  boney
#1 ·
I wanted to know what you guys put in your spec v's.
The manual says that the car will accept 87 grade, but will have better performance with a 91.
Ok, well the compression ratio does not change so why would this car accept both types of fuels. Does it somehow know and adjust the timing?
#2 ·
Most people here will say 93. As long as you're not drag racing the car or doing any type of redlining often, 87 grade will be fine for you. If not, you'll probably knock & ping your motor to death. :eek:
I don't know about advanced timing on the SPEC, but a few people that might know will show up soon.
#3 ·
ok so I plugged some different words in the search and got what I wanted.
I was hoping that it would retard for lower octance gas rather than advance for higher octane... Does that make sense...
I guess what I mean is I am glad the CR is up to the higher octane.
#4 ·
Ah! Yes. I believe that the computer automatically retards or advances the timing a bit, depending on the gas grade.
#5 ·
If you put lower octane gas in the car there is the chance that it will predetonate in the cylinder, especially on hot days or when under heavy acceleration. If this occurs, the knock sensor will hear a pinging (and you will too if you're paying attention, like bb's falling on your hood) sound and retard the engine.
If you ping, it retards
If you don't ping, it doesn't do anything
I don't know the criteria for un-retarding the engine once its been retarded
#6 ·
I believe the ECU adjusts spark timing nearly continuously to avoid knocking. Thus, if the spark timing is retarded, the knock sensor will advance timing once it does not "hear" knocking anymore. On a related note, in the July 2003 issue of Sport Compact Car, there is an article about the 2002 SE-R Spec V that states the knock sensor on these vehicles is extremely sensitive, even "hearing" knock and retarding spark timing when there was no pre-mature detonation. Their fix was to unbolt the knock sensor from the engine (but not the ECU) and zip-tie it to the power steering hose. Note that at this point, the knock sensor would be unable to adjust for pinging, so using lower grade gasoline and the ensuing pinging would eventually cause damage to the cylinder walls. Going back to octane ratings, I believe the manuel recommends 91+ ocatane fuel (Premium grade in CA). This would be the ideal readily-available fuel for the Spec V.
#8 ·
If the owner's manual says 91 octane, then that's probably what's best. However, the qr25de in the Spec V is tuned for performance as it has more torque than Altima (180 vs. 150). The increased performance tuning on the Spec V qr25de would make a higher-grade gasoline more important, though in both cases the ECU would retard the spark timing if it senses any pinging. Using lower-grade gasoline would only increase the chances of pre-mature detonation.
#10 ·
I hear once your retarded you have to stay that way.. LOL :D
#11 ·
The Altima has the same torque rating as the Spec V (180)
#12 ·
Yeah but the funny part is 2.5 altimas recommend gas is 87 Oct all day long....so why would the Spec V suggest anything higher? Its basically a Altima engine dropped in a sentra chassis, so whats the difference engine wise? :confused:
#16 ·
Honestly... I wouldn't put anything lower than mid-grade during the summer times. When the air is hot, it can cause possible lean conditions.. You can definetly run it safely on 87... but it will feel a bit sluggish since the timing will drop
#17 ·
I been using 91 octane up till recently, when gas price skyrocketed well over a buck for a litre... been using 87 since. Initially I experienced lost of power, when i drive the car, the acceleration feels like i have 5 more passengers in the car. but after a couple weeks, that went away, i guess the ECU adjusted and i got the power back...
#21 ·
My bad! :eek: I could have sworn I saw 150 lb/ft somewhere...doh! Maybe they do just expect you to drive it harder. Or maybe it has something to do with the way the fuel map/ecu is calibrated? :confused:
#22 ·
You know I get criticized alot for opting to use 91 when it could run 87. All I say in response is.... My tank lasts a week and half based on my normal driving habits... Going on an average of $3.00/gallon as of late...it has roughly translated to 2-3 bucks more than 87 at every fill-up which would add up to roughly 7-8 bucks extra a month! Thats less than a twelve pack for something I use EVERYDAY and is crucial to me. So yea if it takes 2-3 bucks extra for something I have to buy anyways(gas) then WTF?!?!
