VQ Swap into my B13!
24K views 14 replies 9 participants last post by  MrKrispy1183
#1 ·
Well the VQ35DE Spec-V is cool but I'm really a b13 guy. The spec-v needs some work here and there and I have a NON rusted 92 Sentra XE 5 speed. So now I'm going to drop my complete VQ35DE swapped Spec-V setup in the b13. I will post pics as I'm going. Its going to be a tight fit that's for sure from what I got from measurements but should work. I'm also going to stay N/A. The b13 when done should weigh around 2250-2350 pounds. I'm already making 262 whp. I'm going to do heads and cams when the engine is out. I will be converting lot over from the Spec-V like the full wiring harness and Cluster.
Is there anyone else out there with a VQ35DE swapped B13?
#5 ·
Yea but its not a swap thats un-realistic. I have a plazma cutter and a a couple welders. And I love to FAB! :D . I did the VQ swap in my b15 myself also.
#9 ·
That sounds like a great plan. Ha.
I read that other guys thread, and I saw him mention he was going to use a 350Z's ECU. How would that work if it's RWD? or would it not matter at all?
#10 ·
The timing map is diffrent. You have to swap pins in the ecu to work. I have no idea if the ecu looks for diffrent signals tho cause its rwd... :confused:.
#11 ·
Well thats sweet that somone has done it! Well atleast put it in the car! My will be done a lot faster then a couple months. I have all the parts to do it now HAHA!
#13 ·
How heavy is a B13 2 door, 22-2300? I think a VQ35 is going to be very dangerous with the torque steer. Not too mention very very front end heavy. Maybe a VE30DE is a better way to go?
Regardless, good luck to you.
