1 - 11 of 11 Posts
Went to the strip yesterday. Was so crowded that I only ran twice in 4 hours. SO I called it a day. Don't ask about times cause the track was really hot so they sucked. But here's some pics. of whatI saw there.
DE-T install in a classic. He ran a 14.5 at 98 MPH
My car in drag trim.
A Mirage with a nice body kit. Too bad it wasn't a true Lancer ;)
late,
wes
my site
14.5??? How much boost was he running? Was he on street tires or what?
Ryan 97 Black SE-R
aim Stea1th727
He was running 7 lbs. and 98 MPH is a high 13 SEC MPH so the potential was there. And my times, well, we won't talk about those ;) They sucked!
late,
wes
my site
i'm pretty sure all of the later JDM SR20DET have top mount intercoolers..i think its like 95 and down..not sure..but my bro has a top mount intercooler..and his SR20DET was off of a 93 Nissan Bluebird..
Wallace,
Nismo13GTiR
Ah, only 7 lbs. Not too bad then I guess although a full bolt on SE-R is capable of low 14's on slicks.
Ryan 97 Black SE-R
aim Stea1th727
Something is wrong with that DET. He should at least run a 14.2 @7psi of boost. The engine is probably worked out and need some tuning. Plus the stock boost should be set at 9psi.
1 - 11 of 11 Posts
