1 - 20 of 41 Posts
Im so pumped... After countless tries I've been racing my car since the season started and I been running 15.0-15.1 consistantly. I just couldn't break 14.999.
Today was a beautiful day for Drag Racing...Perfect weather....
Well the 1st run I missed 3rd and ran a 15.593 :rolleyes:
The 2nd run I launched at 3000rpm's and ran a 14.985 :eek:
Here's the kicker the 3rd run I lauched at about 2900rpm's and pulled a 14.798...... :D :D :D :D
I think I still could have done a little better because on my last run I let off the accelerator alittle to early. But the track was getting packed so I left early and very happy
Here's my slip #'s
I got a crappy R/T but I was trying to launch perfectly.
r/t 1.074
60' 2.108
1/8 9.488
1/8mph 74.62
1/4 14.798
1/4mph 92.76
The Safc2 and BSR kit were the final touches that got me in the 14's
Before those two mods I dynoed at 157.95whp and 163.15wtq
After those two mods I dynoed at 165.02whp and 167.59wtq
Hopefully this fall/winter I'll get Cams or a Jwt clutch/Flywheel kit or maybe both :D
Sorry for the Novel but I reallt excited........yay for me :eek:
Do you guys think that cams would knock anothers .2 off my times or am I dreaming.
I figure with a prefect run with my current mods I could pull and 14.6 maybe 14.5.
cams - 14.5-14.4
Porting - 14.3
cat removal - 14.2
Lowering & light weight rims - 14.1
Nitrious - 13.3-13.1
/\/\Does the above sound about right?/\/\
Congrats! The 14-second club is a sweet one! But I think that with all the mods you have, you should do alot better with practice... Your trap speed seems too low for the mods you have... Hmmm...
I'm with your mom
damn that's cool, good time
1 question though, the bsr and a safc only gave u 8whp? dont u get 7from the bsr and at least another 5 from the safc?
Discussion Starter · #12 ·
I thought so too... I ran 27-28 Psi in the front tires and 42-43 Psi in the rear tires. Like I said though I let of the accelerator too soon. I actually though that I made like a low 15's run but it was 14.7 lol
good job man...welcome to 14's!!!
Discussion Starter · #15 ·
I actually dynoed after the BSR and I got 3whp and another 5-6whp from the Safc2.
I don't think the BSR gives you 7whp....others have also stated that its good for 3-4whp.
One thing I did notice ever since I changed my stock plugs out for irdiums my trap speed has dropped.
I have also heard the the track that i go to is slightly inclined towards the end which would also expain the low traps.
I figure i should be trapping around 95mph and its more like 93mph so who knows.
STU STi Build Complete
Yeah, you should be running much better times, especially once the weather gets even cooler. With your mods I would say 14.4's all day with good weather. Where did you race at cause it looks like the humidity killed you. VERY EXCELLENT 60ft. time there, but the 1/8 mile looks slower than it should with those mods. Did slightly miss any shifts or anything? Maybe it's still the humidity because the trap speed looks a lot lower than it should, like a high 93mph maybe? I don't really have a comparison though because I haven't dragged any this summer, just in the fall with cooler weather. But as I was saying, keep up those good 60's, get some good weather, and you'll be throwing down some [email protected] times soon enough. Congrats!
Discussion Starter · #20 · (Edited)
Well it was probably about 75 degrees and not much humidity, so I don't think thats the problem.
I let of the gas to early and it affected my trap speed......possibly???
My car has always trapped lower than other spec's but I can't figure it out.
Stock ride height?
Carbon Fiber hood with scoop?
2.5" Exhaust?
Stock rims?
knock sensor?
/\/\I'm not sure take your pick/\/\
1 - 20 of 41 Posts
