1 - 1 of 1 Posts
So today decided to changed out the struts on my 2006 Sentra base. The passenger side was easy. The lower bolts were both 17mm and came out easily.
Then went to do the drivers side and noticed that the top bot is different, its smaller (15mm nut...14mm bolt) and there is a alignment washer on that bolt...however there is none on the passenger side.
Is this considered normal? Or did someone previously just put a regular 17mm bolt on the passenger side so avoid aligning it.
Also the torque spec for the 17mm bolt is 84-95 ftlb, anyone know the torque spec for the 14/15mm bolts?
Please help
1 - 1 of 1 Posts
