Hello, I am curious which model year doors will fit on my 2003. Two of the doors are rusted through and I would like to replace them. Is it 2001-2006?
Also can I use the doors off of any trim level Sentra?
AFAIK, they should be okay with any year so long as it’s B15. So 01-06. Trim would only matter if you have a Spec-V and want the interior door trim (like above the door handles) to match the seats. Also, the speakers on the doors might be different depending on which trim you get a door from if that matters (since SE-R got the Rockford). Overall I think the most important parts should be the same. Good luck finding one! My car is in the same position :ROFLMAO:. Try asking at B15U if you need more help. That forum seems to be more active nowadays.
