I’m trying to replace a friends ball joint. The ball joints I’ve gotten from Advance auto and Oreily’s are too small by 1mm. They measure 38mm while the one I pressed out measures 39mm. The LCA ball joint hole also measures 39mm.
Does the Spec V require a special ball joint or brand?
Discussion Starter · #2 ·
Talked to a Moog Rep and neither of their ball joints are 39mm. Suggested the whole LCA may have been replaced in the past with an aftermarket piece and that’s why the OE spec ball joints does not fit it. OE ball joint is 38mm.
