This whole thread should be deleted and replaced with a search link, or a PM link.
Benefits of G.C's
1. Ride height adjustment (of course)
2. Spring interchangability (you can get a set of 200f and 250r. if you want it stiffer after that, you can movce the 250 to the front and get a set of (2) 300ft/lbs springs if you want. The springs should be 7" and can be swapped to any location (fr, fl, rr, rl).
3. Proven with koni yellow shocks to be THE best value, and the best performance for value.
4. Corner weighting(if you want it) You get the car weighed, with a separate scale under each wheel. You add the weight from the front right corner with the rear left. Then add the front left to the rear right. You want those two numbers (with you in the car) to be as close as possible.
-t
