The subject line pretty much says it all. Just curious what stock class a Sentra SE would be in for an autocross. I'm too lazy to reference the scca web site.
thanks
-craig
Minch, your car runs in E-stock as long as it's stock. You can run run DOT spec racing tires but you can't change the diameter or width of your wheels.
autocross is..
autocross.com will explain it better than me. I believe it's the largest form of racing in the U.S. It's an SCCA sanctioned event. There are two versions Solo II and Prosolo. One car at a time, racing the clock, through a set of cones. check out the web site it will give a good description.
