1 - 10 of 10 Posts
I am wondering what shocks are you guys puting on your car? I will put the Eibach Sportlines Spring on mine in the future. Will there be a big difference if I use the stock shock with it? or will it be better if i change the shock one time ? like what brand is good?
Also i am wondering if the eibach springs and the shock will both lower the car, and if i use a 17 inch 40 tire, will the tires be hiding inside the well?(with this there will be rubbing right?)
oops my bad.
Not your parent(s)
no shocks/struts out for us yet. try using the search function for this subject. it has been discussed numerous times. :D
if you use the stock shocks you are going to bottom them out on every bump. That sucks.
And from what I hear that Koni's aren't all that great....Correct me if I'm wrong...
1 - 10 of 10 Posts
