1 - 10 of 10 Posts
Banned
at the track, what PSI do u run ur tires with. i guess this only applies to ppl with the continentlal OEM tires on the spec. also could you put ur times (ET and 60ft) with the psi? thanks in advance
Designated Drinker
i ran 30/34 on my azenis and got a 2.13 or somewheres around there. i think the sticky factor might have something to do with it tho....
Poopra King
You should be able to pull a 2.0 easily with those tires. You should try a few pounds less.
Designated Drinker
ill make it a point to try that when the weather gets cooler and we head back to the track...
Banned
Discussion Starter #9
get this, i checked my pressure for all the wheels, the fronts were at 31, the rear driverside was at 35, and the rear passenger side was at 12. yea thats right, 12 Psi. oops! no wonder i was getting 15.60s at the track on sunday!
1 - 10 of 10 Posts
