1 - 7 of 7 Posts
1. I hear you can advance the timing, but you need some specail eqiument...
2. I'm gonna assume that CAI is a bolt-on.
3. I heard the strumn cat-back is.
4. ??
2001 GXE
from a i4.0 to a 1.8?
oh well
The only equipment needed for the timing advance is a timing light and a rachet. If you don't have a timing light though, I guess it wouldn't qualify.
Pullies are bolt on. It's not the easiest job, but it can be done. The Exhaust is bolt on. Headers are bolt on.
The CAI is bolt on, or "hammer on" if you bought the Hotshot. :) It is an easy install though.
Once the cams are available, they will be bolt on, although I doubt any of us would dare tackle that job.
I don't think cams are considered a bolt on. You are adding something internal, not just bolting something to your existing motor. The procedure is in the fsm to install camshafts.
Ryan 97 Black SE-R
aim Stea1th727
the cams are not a big ordeal. once the cash is there after they are available, it will be done.
bolt ons are usually external mods that are bolted up or to the engine. (IE: intake, headers/exhaust, pullies, even a simple NOS system and ECU) i have seen cams in some circles classified as bolt ons, and some as bolt ins. call it a strap on for all i care as long as i get more power!
MY PAGE
WAIT! USE THE SEARCH FUNCTION
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 2000SE:
[/B]<HR></BLOCKQUOTE>
hehhe
*Josh*
*myb15*
(My 88 crx is almost here!)
Basically a bolt-on would be something that would be well......Bolt-on. Basically it's something that you really dont have to modify it just replaces the OEM part or Adds on
Examples of bolt-ons:
Header
CAI
Exhaust
ECU
NOS
throttle body
Pulleys
Cam sprockets
little bit more clear now
Later
1 - 7 of 7 Posts
