2000 Sentra GXE...
Just wondering what kinda of fluid to put in the clutch....never had a clutch befoe, so a stupid question if I had. I would imagine its just standard brake fluid. DOT 3. Works like brake, I think. Am I right? So the same fluid in both master cylinders (brake and clutch)?
you need not change the clutch fluid. i usually change it around 50k miles. it takes brake fluid. so when you do change it, have your brake system bled at the same time. the clutch is fairly simple. have someone inside press the clutch while you release the bleed screw located on the tranny.
p.s. , i do recommend you get the steel braided line from greg at mossy. although not a major diff, my clutch felt stiffer and a fluid change and the new line.
