I own a GXE Sentra 2001 and I am looking to put a little more base in my trunk.
So rather than take up the already small trunk space I want to put in a bazooka tube with a built in amp.
I was wondering if the stock GXE deck has an output for such a unit.
If it doesn't then I will have to upgrade the deck but I like the look of the deck I have and adding a couple wires with banana plugs on the end to put in and out the bazooka would be the easiest.
Thanks.
re: i c
Ok so that is easy then. So if the Bazooka has speaker level inputs then just splice and put wire into the bazooka.
If it doesn't buy this thing and splice wire and put it in that which will goto the woofer.
I see. That sounds good to me.
However the deck I wanted was so nice. :)
JCV SH99........
THis will do for now then. THANKS
