Hello all. New guy here trying to help a friend fix her 2001 Sentra (1.8 auto). She has owned the car for 3 years and it has just over 100k miles on it.
She was complaining about it stalling at lights and stop signs occasionally. She said that it got "worse" and would run poorly. I went to look at the car and confirmed what she saw. It ran fine when cold, but after warming up it would sometimes stall when stopped, but the major problem was that after it was hot the engine lost most of its power. The engine would surge and chug, but never rev over 1500rpm or so. It never completely died, but it was hard to go 20mph.
The check engine light was on so I took it to an auto parts place to read the codes. They were unable to read them. Then I used a small cheap code reader and had the same problem. It could not connect to the ECU.
I followed the troubleshooting instructions for the obdII port and measured the proper power and ground, and the data line was at 7.5 volts which is close to what the book said (book says around 8 volts). We reseated the connector on the ECU but it didn't help.
I don't have a spare ECU to swap in, and there were none at the local junkyard, so we gave up on getting the code reader to work. I took a guess that one of the coils was failing. We bought one new coil and swapped it in to each spot, but the problem persisted. $80 down the drain.
I don't want to just throw more money at this, but without being able to read the codes I have no idea what the computer is not happy with. So, two questions:
1) any ideas about not being able to read the codes?
2) Any hints on what could cause the bad hot-running condition?
Sorry this is so long, but I wanted to include the info I know.
Thanks in advance for any help
Mike M.
Mike M.
