1 - 1 of 1 Posts
My daughter's '90 Sentra XE has started making a noise anytime the car is moving, but only if the engine is coasting or the cluth is depressed. Sounds like a bad speedo cable or drive gear, but it goes away as soon as the engine takes up the slack in the drive train. Makes the noise just as loud with the clutch depressed. Could this be the speedo drive gear? Any suggestions appreciated.
Thanks, Don
1 - 1 of 1 Posts
