21 - 22 of 22 Posts
Discussion Starter #21 (Edited)
6th bolt on the flywheel rounded off... welded a normal t55 bit to the bolt... broke it right out.
Cool. If you're installing an aluminum flywheel tq it down in steps
When I did mine I first tq'd the bolts to 25ft-lbs, then 55, then the final value specified in the fsm. When you do the last step apply the locktite.
I don’t know about using red loc-tire on something like that unless you never want to get it apart again. Also, I encourage you to fill me in on how you apply loc-rite to bolts already in the hole and tight. Is there something I’m missing?
21 - 22 of 22 Posts
