1 - 20 of 20 Posts
i think my tire shine is making my tires turn brown that stuff is really greasy is there a way to remove it easily?
yeah just one of those brushes should get it off...what kinda tire shine are you using? my eagle one spray gel stuff used to do that, plus it got crap all alongside of my car. now i use the meguiars purple gel stuff and i have no problems
Canyon junkie! ( ^o^) <3
Just use a big semi-soft bristled brush & lots of soap. I don't like using those tire shine products since the crap usually ends up on the body of the car. I just like to keep the tires really clean.
&#9733;&#9733;&#9733;&#9733;&#9733;
the meguiars doesn't leave it, you should try
shiney tires look sooo much better :D
Southern Shift Racing
I agree. The Meguires Tire Gel is da bomb. Just put some on a rag (not too much) and wipe it on. I usually will rewipe it after I apply it maybe after 15 minutes to get rid of the excess. That way you don't get it spraying all over your car. And it lasts hella long too, even through rain storms (just as it claims). :D
And it smells good too...like grapes. :eek:
Well, you see, putting a tire through heavy cornering abuse gets it on the body. It's gonna spray everywhere. Besides, the tire is way too greasy! Sliiiip!! Slip n slide, it's a watery... Oh no wait!! A tarmac road!! :eek:
silly, you're not supposed to put it on the tread :p
Not only that but I find that the schine stuff actually makes my car slide when cornering. I have used several different brands and they all cause my car to slide during cornering. So I just stop using tire shine all together.
Discussion Starter · #13 ·
I am using armorall
such garbage
ill definatetly try meguiares
so for the grease already on there just use soap?
my friend told me to use rim cleaner (degreaser)
but then again that fool uses that on his paint too ...... moron.
hehe
thanks alot everyone
armor sucks for basically everything
just water and the brush should work ok, or just use some of the soapy water from when you wash your car
Endless USA S13 Silvia
i'm using this black magic tire shine...its clean.......i put it on my tires and after bout 5 minutes wipe it off.........keeps the tires looking shiny but never gets on my car:D
Late,
Daniel
What turns yor tires brown is the solvent in some tire shines and protectants, water-based protected and shines will work well and not damage your tire or wheel.
Kya, kya, kya!! :D
I use Meguiars Gold Class Endurance Tire Gel. It doesnt fling onto my car, and I like its satin not too shiney finish. I've used the new Meguiars NXT Vinyl/Rubber dressing, and the shiney finish is pretty cool too, but I don't like it as much, as it flings a lil bit.
I used to use Armor All way back in the day, and that stuff turned my tires brown. It also flung everywhere.
Aiya!
I dunno, I've found no product as good at making a shiny dash that shows dust really easily and obstructs your vision by reflecting onto the windscreen, making looking into a sunset that much worse.
yep! and then it will crack your dash! :D
1 - 20 of 20 Posts
