I let my sister borrow my car last weekend, and when she came back she said that she almost hit a deer in the middle of the road and had to swerve to avoid it. When she swerved she said that she hit a a DEEP pothole with the driver's side front tire doing about 20. Now the tire (driver front) rubs against the cars body.
What is wrong and how do I fix?!?
I already fixed the toe (it wasn't even that far off), so I'm figuring the problem is the caster, but i don't know how to fix/adjust that.
For the record the camber on stock B15's is non-adjustable, right?
Forgive me if I seem experienced.
camber is adjustable, what youre thinking of is rear toe that is not adjustable. you really need to lift the car up and take a look at stuff, you couldve popped the ball joint or ripped out a control arm bushing or worse. the entire shock/spring setup could bent over or something. cant really tell you whats wrong without pics, the entire geometry of the all the suspension components comes into play.
