Just wondering what everyones timing is at. Mine was just adavanced and I want to make sure it's on the right one. It was hard to tell which mark to put it on. No more pinging though.
If I am right(pretty sure too) Advancing your timing would only cause more pinging(And you should run super unleaded if its past 16 degrees. I think they must have retarded your timing if it stopped pinging. If you told someone to check your timing cause it is pinging, They almost surely retarded it and that will cause a slight loss in power but you can problem run even terrible regular unleaded gas.
Chrissy doesn't have a B15 SE, does that matter? :) I know stock SE runs at what, 13 or 15? Gosh, now I need to go searching...:p
