okeey.
Installation Time:
30 minutes - 1 hour
Difficulty Level:
2/10
Tools needed:
-Ratchet set
-12mm die (deep socket)
-12mm die (regular socket)
-Scissors or X-acto knife
-Jack
-Jackstands
Hardware Needed:
-8 x 1.25 x 40mm Stainless Steel Bolts - MAKE SURE THEYRE FULLY THREADED (these are metric)
-8mm or bigger flat washer
-8mm Stainless Steel Nuts
Installation Procedure:
1. Clean out your trunk of all stuff, leave it bare down to the floor.
2. Peel back carpeting on sides of trunk. There's a small metal clip on the front side.
3. You can tuck it on the side:
4. With your ratchet using the 12mm deep socket die, unbolt the 4 bolts facing the rear of the car.
5. Okey?
6. Install the top bolt through the oval orifice on the strut tower. Make sure you fully tighten it with the ratchet and the 12mm die (regular shorty)
7. Bottom stud has to be accessed from undeneath the car, behind the rear strut. This picture was taken on the right rear tire.
8. Here is the bolt fully tightened.
Installation Time:
30 minutes - 1 hour
Difficulty Level:
2/10
Tools needed:
-Ratchet set
-Jack
-Jackstands
Hardware Needed:
5. Okey?
