Hi,
I've owned my B15 since April this year, and I'm pretty pleased with it. I live in Taiwan and the car was made here too, so its a slightly different spec to US cars, but most things seem to be common.
There's 2 things bugging me though-
1. The pocket on the rear of the front passenger seat has broken, and I need to remove the rear panel from the seat to fix it. Can it just be prised off? Looks like it can, but don't want to force it.
2. The LCD odometer randomly displays the segments. Every now and again it will show the true reading, flicking it helps, but usually some of the segments will be out. Is it easy to remove? I'm guessing it may just need a clean and re-solder.
welcome aboard!
1-not sure about your pocket, i dont have pockets on the back on my seats. maybe a pic would help? im guessing theyre sticked on, so it might look funny if you rip it off. you could probably bring the seat to an upholestry shop and have them sew it back on.
2-the lcd, there is a bulb behind the lcd if the bulb is going out on you, it can be replaced. if your losing numbers from the lcd, it will need to be resolder if you can find the break. otherwise, youd have to replace the entire gauge cluster.
