Situation:
My dashboard lights, my tail lights, and the warning sound you get when you leave your headlights on and open a door do not work. My brake lights work, my headlights work.
What i've tried:
I've checked all the fuses in the fuse box inside the car on the drivers side, behind the coin tray. I've checked all the fuses in the fuse box in the engine on the drivers side. I replaced the fuse that was labeled for tail lights even though it didn't appear to be broken. I've replaced the turn signal switch.
None of this has changed anything. Any ideas?
What i've tried:
