misfire diagnosis and no start/hard start??
Can someone try to post a checklist (most likely to least likely) of ALL the causes of the hard start/no start problem ?? is ANYONE up to this? i am on my third fuel pump (2nd was a WALBRO). - 2nd fuel canister assembly, 2nd fuel pressure regulator (at the fuel rail), replaced the crank and cam sensors (x1), added my own check valve before the fuel rail, and yet the car is in my driveway and will NOT start!! all of these "fixes" usually last about 6 months, and then back to the same thing,,,2002 sentra GXE (1.8 l) is junk. it only has 95,000 miles, but has been doing it since 64K miles, when i foolishly bought it. yeah, it throws codes, but i have read them so many times, and they are usually different, that i don't even remember them. last one was a generic "misfire cylinder3". could the charcoal canister (and related emission garbage with it) be a cause ?? i know i have seen them codes occasionally, and that is one area i haven't fooled with. i am at my wit's end,,,i can't believe it could be more than 2 things happening at the same time, over and over. there HAS TO BE a root cause. HELLLLLP !!
