1 - 9 of 9 Posts
I've got the Sentra SE with the 180 watt sub system
How is the amp on there?? IF i were to buy two 10" subs (buy one get one free) would I really need to change out the amp?? Isn't there anyway I can keep the current amp and still get a notable performance increase?
Any help would be appreciated. Lookin for suggestions (preferably cheap ones at that)
are you kidding?
are you sugesting running two 10's that are probably capable of handleing at least 200watts each and 6 speakers off of 180 watts! Buy a realy cheap aftermarket amp for like $130 for 400 watts.
I'm just tryin to save some money but get enough to deal with... I can get the two 10"s or even 2 12"s for 100 bucks total... I dont want to get an expensive amp just something that'll do me good....
other suggestions?
If you're gonna get an amp, I suggest Rockford Fosgate or Phoenix Gold. I have experienced both of these personally, and I think they are great. 200W bridged should be enough for two 10" subs, unless you're a bass head.
if you just want a nice sound and not too much without spending all that money for the top brands go to bet buy and get there 2 channel 500 watt amp for $159 i believe or even cheaper you can get the 200 watt amp and it wil still give a nice little sound
SHIFT_my nuts
you'll also will probably need a line level converter. to go to RCAs of your amp from the stock speaker wire...easiest splice. I don't think the amp pushes out enough signal to get it to your amp...much less the hassle of dealing with that pin out...ugg...
1 - 9 of 9 Posts
