1 - 7 of 7 Posts
King of OT
I know the holes in the door for the speakers aren't really threaded like an actual nut would be, but I was tightening my speaker down the other day, and I guess I went to far and the bolt just popped back out, and now I can't really get it to tighten down all the way, what's a way to fix this?
mine did that too. you need bigger/wider sheet metal screws. the threads at the top of the screw are probably bent / stripped
thats why i used bolts for my spacers. 1.25in bolts, fed in through the inside, the the nut on the outside. then, just screw the speaker back into the spacer
problem solved.
King of OT
Discussion Starter #3
problem solved.
Duh......lol. :( Why didn't I think of that.
i hate the fact that i can never tell if you're kidding or not
I did the same thing, I used to use normal bolts just screwed into the sheet metal but that blew donkey nuts. I ended up getting 1/4" bolts/washers/nuts and bolting it to the door.
1 - 7 of 7 Posts
