1 - 10 of 10 Posts
This is my first problem, well hoping it is not a problem, but I just noticed a clicking noise like something is resetting or something. It does it when I turn off the motor, or basically coming from the "ON" position on the ignition to the "off" position. You can barely hear it inside the car, but when I had it in the garage at night when you can hear the crickets and ants crawl, it was pretty obvious. Any thoughts? Thanks
Does the clicking sound come from underneath the glove box? If so, I have the same thing when I turn off the car.
Actually, I managed to isolate it and it seems its coming from the motor right under the valve cover. I might have the dealer look at it when they replace my headlamps since its peeling now or something.
Laloosh said:
its normal, it the throttle body going full open then full close.
Why does it do that? Does it reset it's position or something?
Same thing on my 01 SE as well. When i have the hood up is when i notice it the most. This odd clickn noise but now i know what it is.
1 - 10 of 10 Posts
