anyone have or know anything about the Stillen B15 rear sway bar? is it the same as earlier Sentras? is it hard to install and how much does it help?
as what i saw at stillen shop, it is very simple to install. it is not a true anti-sway bar in the sence it only has two connecting points. real sway bars have four(2 on each side, one on the suspension, and the other connects to the chassis)
i guess it might work.
well seeing as how we have a solid rear axle I don't think that the so called Stillen rear sway bar is going to benefit us enough to urge me to buy one....I'd rather go header / short shifter personally....
-01
well it sounds like junk so far... i guess i could just get some wider tires to help my handling now
I was considering this in the begining but then I found out how it bolts on and I wasn't impressed....So I lost interest really fast....
Fogey
Progress is suppose to have a rear sway bar. They are currently testing one. I've been told it is suppose to be a few weeks but I suspect it will be much longer than that.
