when at a stand still or going slow,when i turn the wheel front left to right you hear creaking but not while driving fast. also when jerking the wheel quickly in on direction with the top to the steering wheel 90 degrees in either direction you can hear a clunk from the steering column under the dash by the firewall. i had my friend listen under the hood for the noises and by each front strut to see if the noise were there but they weren't. so i had him put his head under the dash by the firewall and he said he heard the noises. are the two noises related or is the creaking due to lack of lube? i read on a Maxima forum that the rubber piece where the column goes thru the firewall just needed to be lubed and the noise went away but the clunk idk.
