anyone know the settings for the s-afc I don't have the book for this part of the install
1. hotwire maf sensor type in/out
2. pressure in/out
3. hi throttle/low throttle% +/-
thanks.
Boost Addict
it does not matter what you use for the hotwire as long as the in and out values are the same. 06 is used for a sr20de and 18 is used for a qr20de. both of these settings will work but are not for this maf sensor. the number is only important if you are trying to hook up a different maf sensor to the stock ecm.
