Basics: 2004 SE-R Automatic, just replaced the starter last week.
So this problem has been getting worse. What will happen is this. I go to start the car, and instead of the starter engaging and starting up as usual, about 30% of the time it just grinds on the flywheel, about 30% of the time it starts to crank and then grinds on the flywheel, and about 30-40% of the time it starts normally. I had the starter replaced (which I'm sort of regretting since that didn't fix the problem), and now it's back to square one.
The shop says it's the flywheel, which I believe. However, here's my question that I can't find the answer to (because google is useless when searching for this kind of answer it seems...): if I am going to pay to replace the flywheel, does it behoove me to get a better one like a JWT? Remember, my car is automatic. Second question, assuming that yes, it is a good idea, will this one work?
http://www.horsepowerfreaks.com/partdetails/Jim_Wolf/Flywheels/Flywheels//4972
...or do I need a different one since it's an Automatic? I can't seem to find this information anywhere and I don't want to ask the auto shop because they will likely tell me whatever they want to make money off me.
Final question: If I can't use that one in the link above, can someone point me to a good replacement for a 2004 automatic SE-R? I'd rather buy it online then have it put in...much cheaper that way.
Thanks in advance...sorry if I broke any forum laws or whatever. I researched, I just came to a dead end.
