1 - 8 of 8 Posts
Super Moderator
They should have come with an install diagram. Let's save some time right off the bat....do you have an SE, GXE or XE? It'll make a difference.
Oh, they didn't come with instructions, but they're for an SE (rear). I don't see any screw holes - do I have to make some myself or am I missing something (probably)?
The kit should have come with self tapping screws. YOur right, there are no holes, but you will see indentations where the holes will end up. It's really easy. Just be sure you have the mudflap lined up properly. The bumper is plastic, and is fairly soft.
Super Moderator
It's easier if you take the tire off first.
Or u can turn the wheels to clear the fender! That might work too!;)
Super Moderator
Good luck turning the back tires. 4-wheel steering would be a wierd modification for our cars. :)
1 - 8 of 8 Posts
