The P12 internals were put in this spec-v case. So if you are looking for a 4.7 final drive this is what you want.
Its open diff so IMO you should put one in it... With that in mind did not RTV the case back together when I assembled it.
I also noticed the shifter mechanism was bent in shipping so whatever trans you pull a HLSD from you'll need the shifter mech. also.
$400
Located in Kinston NC
Perfer local pickup
The gearing is
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th 0.809
6th 0.673
Final drive 4.75
$400
Perfer local pickup
The gearing is
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th 0.809
6th 0.673
Final drive 4.75
