Bought my spec - V used. Aftermarket shift knob because it matches the paint and is oh! So cool.
Anyways looks like the adapter was plastic, and very cheap plastic as it cross-threaded when I tried taking it off. In all fairness: the knob itself actually seems to be quality enough. It's either aluminum or a very light steel.
Any knobs that fit the actual metal shiter? Not sure what to do here. It works, but the knob twists and turns while shifting, witch at some point will be pretty bad for my trans. Don't want to look into a scrap lsd,fwd trans. So can I please get some info on knobs that fit and are quality?
2J Racing had two in their site. Sick speed sells tons of them. Amazon has some. It has to be threaded to 10x1.25. if you have reverse lockout on your shifter check that first.
I have one ordered from 2j arriving this weekend. Stock shifter fell apart in my hand this week.
Fell apart in your hand?! That sounds scary as hell!
I have the one that's faulty screwed on and it reads R in the first gear. Works for now but the adapter is stripped and cracked, so that's worrying.
I didn't know the threads were different for models with the lockout, mine has it but it's broken.
Thanks for the advice!
For 2019, 2JR releases the ultra detailed V19 two piece shift knob. The upper colored section is swappable with the lower stainless section. For the upper you can choose between Delrin, Aluminum, Gloss White, Candy Red, Candy Blue and Candy Purple. Yo
For 2018, 2JR releases the ultra detailed V5 shift knob. Very limited quantities and built to order based on your spec of vehicle. First you can choose either a Delrin Black Top (7.4oz) or a Billet Aluminum Top (9.3oz). Each come with a stainless stee
Taking cues from automotive nostalgia, this knob features a shift pattern etched into the surface of the knob. While keeping the pattern from rubbing off, the engraved design also adds that classic feel to any ride. These billiard-ball quality shift knobs are designed to be the HIGHEST QUALITY...
Buy VMS Racing 10x1.25mm Thread 6 Speed JDM Round Ball Shift Knob in Gunmetal Grey Gray Silver Billet Aluminum Compatible with 03-08 2003-2008 Nissan 350Z Fairlady Z: Body - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
They are all same threads as far as I know. I think 06 has reverse lockout. Is your car an 06? If so you have to make sure the say it works with reverse lockout. Mine is 04 so I don't have that problem.
It's an 06, but the previous owner broke the lockout, so I've just sort of got a bushing and a spring floating around on the shifter. Idk where he got the knob, but it's really weird. I'm assuming it's aluminum, but the recess and threads are about 1/4" away from the size of the shifter. Instead of threading it correctly looks like it came with this oversized adapter, but the things made out of some of the most brittle plastic I've ever seen. Dollar store toys are genuinely made from better plastics than this thing. I'd take a picture, but the adapter started falling apart like a mummy being exposed to air after 10k years, so the next time I get it off it isn't going back on.
Quality is great. Totally satisfied. Needs a little if the lightest loctite To keep from coming loose. Feels amazing compared to stock. Gets pretty hot in summer heat though.
Related Threads
B15 Sentra Forum
2.5M posts
41K members
Since 2000
