1 - 9 of 9 Posts
Is there any trick to removing the shift knob, or do you just turn it really hard until it comes loose? I don't want to **** **** up.
take the shifter out of the car, wrap the knob with a towel, drive over the knob with the front tire of a car, stick a screwdriver into the hole at the base of the shifter for leverage and unscrew the shifter rod from the knob... I re used my stock knob on my SMC short shifter with no problems
Super Moderator
From my readings, I guess the shift knob is on REALLY tight. That's the difficulty.
Bow to your SE GOD
Good luck. i ended up cutting the leather knob down the stitches on one side to get it off. It's tight like a nun's well, you know. Then I cut 2 1/2" off the shift lever. 'SMC' my butt!
1 - 9 of 9 Posts
