dydigital said:Ok the code I got is--0455-- EVAP GROSS LEAK....................................
So does this mean I have a leak somewhere with the CAI?
So could this make the car idle higher? Also could the stealership blame my intake for this? If so, I will take off the CAI b4 going to the stealership if the light comes back on. I reset it for now, I hoping it don't back on. But my car still is idling high, at about 1000-1100 rpm.cortrim1 said:its a code for the evaporator purge control valve. it means the valve may have got stuck or malfunctioned. I got this code a few times after adjusting my safc-2. I would just reset the code. if it turns back on with in a day or two the valve is not working right. its part of the emisions system just in case you were wondering.
reset procedure.
http://www.b15sentra.net/forums/showthread.php?t=76692
david said:Its usually the gas cap isn't tight enough. Tighten it up the light will go off in like 100 miles.
