1 - 20 of 41 Posts
is there any way for you to change when the secondary runners kick in
my freind drove it the other day and was amazed it kicked in so late and told me that the honda v-tec had something the changed when it would kick in
i have heard that the vtec afc controller wont work on the spec-v's
unless yhou are talking about the jet controller
sorry a bot cranky. been at work since 7pm and still have 6 hours left
also tired, you could telll by looking at the way i am spelling my words
Discussion Starter · #9 ·
well if there is something i would like to set the secondary runners to open at 3500-4000 rpms cuase i never really hit that high unless i'm running her wide open
yeah it would be nice to have something to have that kick in earlier. The only time that i really get up to 5000 is at the track.
what kind of nitrous do you have and how is it put in the motor?
I have a 50 shot of nx (wet) fogger before the intake
ok i think this topic has been beaten to death.. secondary intake runners this that leave em open...tie em up...lets make em kick in earlier like v-tec...blah blah blah.... its not vtec!!!!!! you cant control them with anything...there are noooo gains if you could open them earlier...theres a reason they open up after 5000 rpms. At 5000 theres enough velocity to be able to start an increase in pressure by technically enlarging the inner cross section area of the intake runners...although its not really like this, this is wat those secondary intake runners opening up simulate. You would lose low end torque and might possibly cause a decrease in intake air stream velocity by opening them up at a lower rpm...you dont want that
Boost Addict
opening the runner earlier or later would provide no benefit unless you could change the cvtc system to optimise the extra air. the runners could be made to open any time you want with a rpm window switch hooked up to the vias solenoid. btw I have dyno tested a car with the runners zip tied open and the car lost power through out the entire rpm range.
Theory freak learning...
Maybe with cams we could see a small gain to open the runners earlier but otherwise, I think it's useless.
I add this page from the FSM to complete the infos too how the VIAS system works ;)
Immature Tough Guy
I agree with pretty much everything in your post...although, don't you find it interesting that toward the end of the FSM page angel listed you have the phrase:
It [VIAS control solenoid valve] responds to ON/OFF signals from the ECM
Another option would be to completly remove the selenoid and the vacuum actuator and use a step motor instead. Something like our electronic throttle motor that will allow precise degree of opening instead of a full close or open runners.
Setup like this as been done in the past for the Probe/MX6 3-stage intake manifold (2 sets of butterfly) and conversion kit are available on the market.
But this would required hours of tuning on a dyno to acheive full gain and would apply only with the actual mods on the car. But maybe for an N/A beast with full bolts-on including cams, that mod could worth of it...
Poopra King
Now that's the best idea about this subject I've heard up until now.
1 - 20 of 41 Posts
