The radiator in my wifes GXE just started leaking and after some looking, I have found a 2 core aluminum radiator for $40 more than a factory replacement, but it is only listed for the SE-R/Spec, it looks exactly the same. I am just curious if it will work in a GXE or if anyone has made it work, what did you do?
i mean you can make it work. the hoses will be fairly straight forward, just connect them, but im not sure if it mounts the same or in the same place. if the gxe is auto, make sure the radiator has the lower cooling lines on it so its just plug n go.
