I know you wanted a link but its pretty easy to explain. Just pop the top bin out by sliding it toward you and it should slide out fairly easy. Then pop out the bottom map bin by pulling it toward you from the rear, this one is a little harder to pull out but it will come out. Next you just unscrew the six screws holding the frame in and pull it out. The rest is pretty self explainatory so good luck. I know its not a link with fancy pics but if you follow these instructions you should be alright.
if you have a rockfordfosgate HU, i'll buy it from you...granted the cd player works perfectly, and its in perfect condition with NO scratches
Iknowyoulovereadingso..
a word of advice..disconnect the neg terminal from the battery when pulling/putting a head unit back in..you can blow a few fuses if you dont..its just a safeguard against spending hours trying to figure out why your stereo wont come on.
