Hello, sorry if I didn't post this in the proper spot. I've been trying to find the tach signal wire for my remote starter but every guide I find says to use the red wire at any ignition coil which I do not have. I have a 2001 SE 2.0 and it has distributor but not a "traditional" coil that is separate from the distributor. Is there a wire on the plug that goes into the distributor or behind my gauge cluster I could use? I've been browsing for a couple days and have yet to find any info, any help is greatly appreciated. Thanks
Discussion Starter #2
Got it figured out. The previous owner or installer had the second ignition wire on the incorrect wire. After going over every wire I switched it to where it was supposed to be and it fired right up. Not sure how to delete thread so wanted to reply at least.
