i started with JE 9:1 racing Pistons and rings, 07 Crankshaft, block board to 88.5mm JWT Valve spring upgrade, JWT balence shaft removal kit, JWT 630cc turbo tune, ARP ford cosworth head studs, Felpro Complete gasket kit, new oil pump,water pump, aem fuel regulator, complete turbo kit. My motor has about 8000mi on it and im still going threw about 1qt of oil every 1200 miles. I am concerned about this. Should i be worried. I rebuilt the motor cause i cracked piston 2 running stock internals with a turbo with SAFC Apexi Neo. Then i had a problem with oil on my bumper befor my cracked piston. I currenttly dont have oil on my bumper but still going threw it. any ideas would be helpful. i did everything to prevent engine feilure. i broke the motor in properly, i didn't start fully spooling till about 1500mi. also im haveing issue of proper fuel pressure.
