Well this mainly goes for the guys who have the 1.8's with an automatic, but hey it can be really for anyone... Just lettting you guys know that the "cool radiator" can fit on our cars perfectly... The 2.5 and 1.8 have the same fitment with this radiator... so I purchased this radiator almost 2 weeks ago because I needed one and just installed it this morning... only problem is that your going to need 2 separate transmission lines because this cool radiator is only for antifreeze coolant... You can go to autozone or any auto parts store and pick up a "transmission cooler kit" so you can run the 2 separate lines into it... the kit should cost anywhere between $30-40... just a small one (the kit contains one hose, small radiator (probably 5 inches high and 7 inches across would be perfect) and clamps with these little wire attachments to brace the cooler... Also I must advise anyone that will be getting this radiator that will be doing the tranny cooler install to get more tranny cooler hose (it's about 5/16 size), get about 6-7 feet of it, also more hose clamps for the small hoses and larger hoses such as the radiator hoses.. them screw in clamps are good
Well I must say, the install went well and everything is good... only bad thing about this radiator is that its hot on top
Theres no cover or plastic
Well if anyone needs help with the installation or wants a "how to", just pm me... too tired to type...
