Car is a Nissan Sentra B15, 2001, with a 1.8L engine.
Last Thursday I was driving home from work when the batter and hand-brake lights lit up. The car was driving ok, but I played safe and didn't drive it on Friday.
On Saturday, after checking out this forum, I changed the alternator. O'Reilly said that it checked out OK and so did the battery, but we changed it anyway.
Battery was showing about 13.5V, alternator was putting out about 14.2V.
Went for a test drive - all OK. Went to pick up son from college, and after about 25 miles the airbag light started flashing, together with the 'O/D Off' light. Car didn't want to go more than 60mph, and got slower and slower, until it stalled altogether about 2 miles from home.
Towed it home, and checked the battery - about 11.5V. Jump started it, and it was fine.
On Sunday I thought it was the grounds, so I hunted down all the grounds in the engine compartment, took them off and ground off any corrosion until I had bright shiny metal on each of the mounting point, the tail and the bolt (found 5 grounds - one near the battery, connecting battery->chassis->engine (a big one), two on the rocker cover (little connections), one by the alternator to the front of the engine, and one behind the washer bottle. FSM didn't indicate any others.
Went for a test drive. At one point, accelerating hard, the battery and hand-brake lights flashed on for a millisecond. Got 9 miles, and had the same situation again; airbag light and 'O/D Off' light started flashing, engine lost all power (luckily I was pulling into my garage when it happened). Checked battery, it was about 11.6V. Left it for an hour or so, and battery was up to 12.3V (dunno why). I was able to start it for the 10ft drive to the end of the garage.
There are no check-engine lights on. Even so, I put a code reader on it to verify - there are no codes being tripped.
I did think it may be the battery (despite Oreilly saying it was good) - but if so, surely the car would still drive once it was moving, because the alternator would be supplying the current? Or am I wrong? Don't want to throw another $100 at it unless it will cure the issue.
I'm at a loss. Any ideas on what it could be, or what else I can check?
Thanks in advance,
Pete.
Thanks in advance,
Pete.
