I am begining the install of the PR CAI.
How did you get the lower part of the original intake out? Do I have to remove the front fender? What tools do I need to remove it?
You have to remove it from the fenderwell. There are several pop-out clips on the inside of the fenderwell, along with 1 or two screws. It comes out from underneath. Look at the fenderwell of your car, and you will see what I mean. Its very easy. You don't need to take it all the way off either. I managed to squeeze everything in by just pulling the plastic liner back.
yyyktk1 said:
Great.
Thanks for the info.
I guess it would be easier if I removed the wheel? Right?
You really don't have too but if you think it'll help then by all means do it.......but be carefull pulling those tabs out that Maxx is talking about cause they are fairly easy to snap.....but the install is really easy and straight forward,,really nothing to it.....did You look at the instructions on the www.b15sentra.net site?? If not then look at the free air mod and it gives you excellent instructions on taking out the OEM boxes......Good luck:)
