I installed this kit a couple months ago and absolutely love it~!!!
It has really helped settle the body roll problems this car has had since new.
I did have a few problems getting the front bar in place, I had to drop my rear motor mount about an inch to get the new bar to pass through the jumbled maze of parts down their.
The rear gave me some headaches because the bolts that fasten the bushing plate (the ones that go over the bushing and attach to the mounting plate) were to small and just would not thread up without trying to crossthread...so be aware of that when you do the install, and leave plenty of time to do it right, torque your bolts properly and you will also need a tie rod end removal tool to pop the ends off and out of your way on the front. The tool I used put a small slit in the rubber boot and eventually I will have to get new ends to replace those since water can now get into them along with dirt.
It's worth it all though so don't worry about the small problems I had...it may not happen to everyone.
By the way I paid $269 U.S. for my set, I don't know what that is in Canadian though.
