Been getting this code on a 2006 sentra. Just replaced the TB with a Hitachi replacement factory unit, but still getting code.
The FSM says that either the wiring is bad, or the TB is no good. But since the TB is replaced, I was wondering who else has had this issue pop up or knows a common fix at this point.
Car starts fine. After clearing codes, idle is a bit high. Code gets thrown the first time you press the pedal. The FSM says that the pedal sensor will not throw this code, so I would guess this code is localized to just the TB or wiring. However, I don't want to keep throwing parts at this issue. It could be bad wiring, a bad ecu, bad ground somewhere...
Hopefully this issue is common enough that someone here can help. Google hasn't been helpful.
After replacing the TB, is it absolutely necessary to do the idle relearn immediately to prevent the code? Any info on this issue would be greatly appreciated.
