1 - 9 of 9 Posts
Iknowyoulovereadingso..
ok..ive just noticed something weird, a majority of the people on this board have said that the + or - wires of the battery cables had to be lenghtened to fit the #35 red top. Thats wrong, atleast on the Se's but i assume the same wiring was used on the ser/spec.. I DIDNT have to lenghten either one and all it took was unclipping a cable holder.
first remove the stock battery ( dont think i have to explain this in detail lol)
look at the big positive cable thats attached to the positive clamp that goes on the battey, trace that down like 12 inches and you see its held in place by a clip. The only thing you gotta do is open that clip and take the wire out of it. then put in the red top(with the plastic riser thing that comes with it) to make it level with the wires. maneuver the wires around the battery and viola! connect everything back up. the stock battery brace works with the redtop and so do the batt ties but i new batt ties cuz mine were rusty.hope this helps
heres the postitive wire with the clip opened. the clip is near the middle right side of the pic
again you can see where the clip is, between the airbox and the battery at the middle
the complete look
EDIT:: this is NOT the optima with the reversed poles. Its the regular one.
I bought a red top for my '04 Spec, and it did not fit. I did release the clip on the + wire and it still would not reach. My neg wire was to short as well.
Nissan RICE Division
Did you try the Group 35 battery? Seems like those are built for our cars. I have an SE too, but I got a Group 35 battery and everything lined up perfectly.
1 - 9 of 9 Posts
