Hello, all.
As I was rather close to the end of the 1000 mile break-in period on my '01 SE, I attempted my first oil and filter change on the vehicle a few days ago.
After draining the oil, I attempted to remove the filter, only to find that the factory-installed filter (Part# 15208-65F01) is an oddball size that is slightly too small to be unscrewed using a capwrench. The intended replacement filter (Part# 15208-65F00) is the same one used in my '95 200SX SE-R, and *does* fit the capwrench perfectly.
As I was unable to work the factory filter loose with either the capwrench or by hand, I filled the engine with new oil without replacing the filter. A quick phone call to the service department of the dealer revealed that the -65F01 only came from the factory and that all in-service replacements use the -65F00. The tech rep also told me that the only way to safely remove a -65F01 was to wrap a piece of cloth over the filter and then jam the capwrench over it.
D'oh!! Why didn't I think of that???
Anyway, my question to you guys is, can I safely remove the oil filter from the SR20DE block *without* first draining the oil? In other words, if I unscrew the filter, am I going to end up with 3+ quarts of engine oil on the garage floor?
Thanks in advance!
DL
Al, The Ignorant Fcuk
Yes..
You can remove the filter without draining the oil. Some oil will drip out because the filter should stay full because of the anti-drainback valve. (8 oz.) Be ready with some paper towels.
Re: Yes..
Thanks for the heads-up, adc100. I finished changing the filter about an hour ago, and you were spot-on about the oil remaining in the filter. I had paper towels ready and newspaper lining the garage floor, but most of the oil in the filter ended up dribbling down my right forearm and into the shirtsleeve as I unscrewed the filter. The result: one completely ruined "Today's Weather SUCKS!" t-shirt and me smelling like Mobil 1 for the next few days (despite a shower after the drenching).
The next time I remove the filter, I'm going to position a small funnel under the seal with a short length of tubing running from the funnel to the drain pan, in order to capture the oil from the filter. I think there's enough space under the filter for this. No more ruined shirts for me!
DL
Glad you made out O.K...
Forgot to mention about the shirt though. I'll remember next time!!:D
Oh .. and glad to see you are using Mobil 1. You won't regret it. :)
Later,
Al
Yes, oil down my arm happened to me too... But next time I managed to position myself so that I unscrew filter with my hand above the filter... If you unscrew it very carefully, then you can even manage to take it down in the same horizontal position w/o spilling any oil... If you don't tip it, oil won't spill since its not really full, only 1/2- 3/4
