I did a quick search for "wheel offset" and after some skimming it seems the factory offset for Spec's is
'02-'03 = 47mm
'04 = 42mm
It seems that anything from 40mm-45mm is just fine... unless you have an '04 with the Brembo option.. then you are going to have a much harder time finding wheels that fit.
